Help This is nuts
My truck wont start after fuel filter change. I have a Code P2291.
I have no clue what's happened. I have never had this happen before. :dunno
Tbar
SDD STAFF/Moderator
Sounds like you have air locked the system. I am not familar with that engine to suggest a way to get it out.
Tbar
There is air in there, but I have not been able to get it all out. I have google it there is not much out the on it.
Thee 'ol.. Key On, Shop Vac in the fill pipe.. putting some pressure on the tank & fuel system trick.. maybe :dunno
Tried that, no go. I have fuel at the top filter, it's in the fuel rail.
550Tommy
Fordologist since 78
Southern Green Mountains (Vt.)
QUOTE=BIG JOE;247323]Hmmmm.. Try cranking it ? With pressure on the Tank ?
This is the right method, need to keep positive pressure until you push that air out and clear fuel is headed to nozzles.
There's always the taboo trick...bottle feed it some sniffer gas from the can...but I didn't say it.:nono:
Tbar
SDD STAFF/Moderator
Batteries down from cranking.........may need a recharge???
Tbar
I did the next best thing. I walked away from for a few hours and played with my grandson. Took the jeep out on a beat run. Said a prayer. Then it started after 2 tries. ;tu He take care of me inspite of my self.....
