fordzilla01
- Joined
- Oct 18, 2007
- Messages
- 4
- Reaction score
- 0
Ok, I just went on a 5000k trip and on the way back my truck (2001 F350 7.3) started doing the weirdest things. First the turbo kept blowing off pressure at much lower RMS than it should (BTW I was towing about 6k and had a camper on it) usually about 2000 RPM or so. it normally doesn't blow off until around 2600-2800 RPM with a load. So it became almost impossible to do more than about 30k up standard hills I should fly up. I pulled over at the side of the road and checked for codes, I had a code saying that the Barometric sensor had a problem, and I had a code that said that my turbo pressure sensor was having probs. I cleared the codes and returned all programming to stock. All was fine for about 10min when it began to progress again from slight problems to the point at witch I couldn't even drive up a hill. Cleared codes again and all as good for a while.
After reading online through this process I found something that said to disconnect the MAP sensor if these codes were coming up, I did so and the truck ran like it was brand new again. (BTW Disconnecting the MAP sensor is the only thing in this whole process that gave me the check engine light in the dash.) I drove for quite some time, satified that the MAP sensor was the problem until the truck began to miss and run like a bag of crap. I was now unable to even go faster than about 30k on straight roads.
I hooked the MAP back up and pulled more codes, now the codes were telling me that I had an "OPEN CYL 7 Circuit" and a few other major weird ones that I can't think of right now. I cleared them and that didn't fix the problem.
After letting the truck sit for about 10min all was good again. Then after driving for the ferry it acted up again. Getting progressivly worse.
I got on the ferry (FINALLY) and let the truck sit. 1.5hours later I leave the ferry and all is fine and no problems now. Now that I am in my own town I figured I would TRY to make it happen again, so I shift @ 2500RPM and work the truck a little to try to heat it up so to speak. And the turbo begins to blow off pressure early again @ about 2000rpm and the lack of power and trubo problems return, but no codes now. I removed camper and trailer and now I can't even make it return by beating on it.
It appears that this problem is somehow HEAT related maybe? My truck requires a major LOAD to make this happen...
