HELP!!! In a hurry!!!!!
vinceismyhero
Tx
Trying to tow a trailer tonight but I cannot get the trailer brake controller to come on. I have never used it before but it came with the truck. After plugging in the trailer all the lights work but no lights come on on the controller on the cab. I checked the fuse under the dash and it was good. What is the problem??? 2003 6.0 psd fx4
Tbar
SDD STAFF/Moderator
Someone in the know should be along shortly with some ideas........in the mean time lets keep this in this forum only.
Tbar
check the connections...might not be plugged in (under the dash)...
check all the fuses...under the hood and the dash panel.
one other thing....if the brake controller is connected you should
get some lights or SOMETHING on the brake controller...try moving
the manual brake lever on the controller, if you dont get anything
that way then theres a connection/power issue at the controller
if the brake controller confirms as being connected and you move
the manual brake controler w/OUT a trailer connected you should
get some error or ALERT that shows an open trailer connection (which
means the brake controller doesnt see a trailer plugged in)
do you get any parking lights on the trailer when you turn the truck
lights on ????
vinceismyhero
Tx
parking lights come on. where is the fuse under the hood located? can't find it in the manual
parking lights come on, on the trailer ? whats the brake controller
show when you turn the trailer lights
on & tap the brake ?
vinceismyhero
Tx
yes all the lights come on the trailer. no lights come on at all on the controller no matter what I do. Do you know where the fuse box under the hood is located?
i dont, unfortunately.
in the early superduty trucks there
was a relay under the hood that
needed to be installed.
i know my 04 (6.0) didnt need
anything...just plugged in a
controller and everything was fine.
the relay/fuse list is in the owners manual
Brad1103
