man you are SO gonna love those AMPS...
I cut the carpet (had to basically use a die grinder / whizzer
wheel) on the 2/3 seat side...the carpet is backed w/ something
like fiber glass !
hey while you have the carpet down off that wall (to cut it)...
why not cover the rear wall in something like hush mat or dyna
mat (dyna mat is over priced in my opinion & take more prep
work to install/stick).
regarding the Vents...they stick INTO the cab a bit...
i TRIED like heck to trim mine enough to get my sub box
in but there was NO WAY...i wound up SEALING the vent
(w/ ac/dut foil tape AND multiple layers of duct tape)...
you DONT want that thing leaking....specially if you have some
speaker box or board up against it...i check mine once in a while
and so far so good (its sealed from both sides).
cant wait to see pictures of your set up !
I think if i had to do it all over again <and its ALWAYS a work in
progress> id mount speakers in the rear door 1 Higher and 2
direct to the door....for a amatuer i dont think i did too bad
w/ the rear doors...but i could be alot better.
i STILL wanna add a set of q-logic q-forms
the qforms would make it a nice EVEN (4 pairs) or 8 mids & 8 tweeters (plus the sub)
i mean wth i have 2 unused speaker channels on the JL e4300 (fill amp)
