They aren't that bad - just make sure you get the right ones. There are two different lengths.
The glow plugs are pretty reliable. Hard starts are more likely to be a FICM issue.
Could also be related to injector stiction (oil latching) also. Oil that is old or too thick can cause injector performance issues. 5W40 synthetic helps, some have had luck w/ a product called RevX. The newest flash from the dealership is designed to help also (if you haven't had a flash update in the last few years).
