Gauges will be in soon! pre or post turbo!
Fire1
Certified Diesel Driver
If it is 1/4" NPT like mine then I have the bits and Tap to use also.
Scar13
Little elm, tx
Thanks Guys!
Wife should be ordering this week for me ( birthday and all )
Illg et back to yall when I have them in Hand and thanks!!
Wood County Tx
me to
and pre is the best, piston temps is the critical first OMG that thing is hot temp to watch for
HTRDDSL
HTRDDSL
St. Albert, Alberta
Pre is definitely the best. I had the sensor installed and they put it in post turbo but I made them change it. There was a difference of almost 150F at 70 mph.
roosterdiesel
Earl needs B100
Amarillo,TX
powerboatr said:
me to
IMO, pre-turbo is best. The exhaust in the manifold is closest to the aluminum pistons which has a melting point of around 1250 degrees. Granted the piston oilers will help, that's why burst over 1300 don't burn holes in the pistons.;) The turbine fins are inconel I think, if not it's something that holds up to the temps better than the aluminum of the pistons.
lvnalolife
Not a newbie.
Las Vegas, NV
Actually the melting point of the pistons is about 1600 degrees. And I also recommend pre-turbo. I removed my manifold to drill as suggested by Banks. I had the six gun installed and that is what the directions say. I have heard people argue over that subject a lot. Pre for me.
roosterdiesel
Earl needs B100
Amarillo,TX
Is that 1600 because of the squirters? All the books I've read about metallurgy(I'm a former machinist) shows aluminum melting at 1220.6 F.:confused: I guess the alloy used by Mahle could bring it up some too.:dunno Sure hope you don't know that # from firsthand experience.
Interesting about the instructions from Banks saying to remove the manifold, all their kits have the down pipe drilled with a bung for the pyro.:confused:
Nice truck lvnalolife! Welcome to SDD! I'll be in Vegas the first of June for a trade show, maybe we can get together.
