gas in 6.0 Powerstroke :(
W4RLR
High Tech Hillbilly
Sewanee, TN
Let me guess, she filled up at a BP station? Those stations are notorious for having green handled nozzles for regular gas. Everywhere else green nozzle = diesel fuel. The marketing bozo who thought that up should be taken out and hung by his private parts. Back when BP was Amoco, the nozzles were black, white, and gold, depending upon the grade. Switching one of the nozzles to green to show how earth friendly the company is shows nothing more than stupidity.
Glad that everything worked out. Replacing an engine is an expensive proposition.
fordtrucker4life!
I work with waste
SE Michigan
Only a powerstroke will be brought back from the edges of hell. You are lucky she fired back up. Could have melted pistons and rings if it ran to long.
Maintain
Platinum Edition
Elkton, MD
A diesel will run on gas it just won't have any go. A few minutes or miles of running on it shouldn't hurt it.
Siphon it out and then refill with diesel and you should be about good to go.
Looks like you've already got it though.
Good going. That is great news. No real need to panic if you do something positive like you did.
addicted
Ft Rucker Al
YAY!!! Glad that was saved. Agreed did you use a BP station. When I first saw that I could not belieive it. I about crapped my pants when I saw they were all green.
Since I've moved here to NC colors are just random at places. Seems color has no meaning here. Just whatever they had left over in their sheds :) I always make sure it is green when dispensing before going full tilt.
Glad to hear your truck made it. The testament to one of fords lesser built diesels engine models. If it could do it we are all in luck :)
DragonSlayer
Pensacola FL
good deal!!:sweet it happens more than you think. i was at tom thumb and was not paying attention, pushed the diesel button and then picked up gas nozzle, good thing it was like that or i would have had the same problem. remember when the only diesel pump was way out back with no cover and no pavement around??
nakahama001
fl
hell yeah dragon slayer im only 19 and i remember those days and yep it sure was a bp and another funny thing 2 days after my incident my dd who has an 07 lbz duramaxi pad did the same freekin thing and cooked a piston all i can say is built ford tough
Ricksofla
