May 2, 2010 #1 L Lineman SDD Junior Member Joined Apr 3, 2009 Messages 6 Reaction score 0 Location Dexter/Michigan/USA anybody else have problems with water separator plug froze in fuel pump housing? going to try jb weld a torx tool in there to get it out
May 2, 2010 #2 atk Moderator Joined Nov 12, 2006 Messages 2,874 Reaction score 0 Location simcoe, ontario, canada yep....ended up replacing hole end cap.... you can try a torx bit, it may work....
May 2, 2010 #3 L Lineman SDD Junior Member Joined Apr 3, 2009 Messages 6 Reaction score 0 Location Dexter/Michigan/USA yeah i tried the torx bit with some jb weld it didnt even budge it ill have to end up replacing the fuel inlet cover
May 2, 2010 #4 J Jetpilot1 Full Access Member Joined Oct 4, 2008 Messages 156 Reaction score 0 Location Fort McMurray/Alberta How often do you pull that plug?
May 2, 2010 #5 atk Moderator Joined Nov 12, 2006 Messages 2,874 Reaction score 0 Location simcoe, ontario, canada Jetpilot1 said: How often do you pull that plug? Click to expand... mine was siezed when i bought the truck, (that was over three years ago). i personally drain the HFCM at every oil change(every 7500km) and when the fuel filters are changed....
