Couple hints Dennis...
Back the FPR houseing screws out, and back in, Equaly.
Try and remember how much "umph" it takes to break the fuel return line nut loose. Use the same umph... to tighten it back up.
Reason ?: The whole exsternal assembly is made of Pot metal. It'l crack & snap off from un-equal/to much "umph".
Use a Bungee to hold the fuel line back, while you work.
Put a rag down in and under the FPR area, to catch things that >WILL< fall. And they >WILL< fall.
I use the #4 SS washers, in the bottom of the spring cup... but if you use something else... in the FPR cover (?) you can use a dab of grease to hold, the something else, in place, while you put the FPR cover back on.
JOE
![dunno :dunno :dunno](/styles/default/xenforo/smilies/shrug.gif)
JOE
