SMOKNZ
I finally got around to hooking up my Diprocol Fuel Pressure gauge this morning. I installed it with the supplied Isolator and filled the cavity with antifreeze after I gently pushed down the diaphram in the isolator. I am only getting a little over 20 psi of fuel pressure. Is there a special bleed procedure I need to do with the antifreeze in the isolator to get an accurate reading, or is my pump just shot. Truck seems to be running OK.
Bill
Bill
