Fuel mileage towing
jascot
OK, I know there is another thread regarding this, but I disagree with some of the numbers guys are posting about towing. I tow a 35 ft fifth wheel, loaded at about 12,000 lbs, going from Phx to Glamis, which is fairly flat I get no better than 8 mpg.
Now the real question is what mods have been done to achieve these numbers.
My truck is 2004 6.0 Super Duty, although I just installed a MBRP turbo back system and cat delete.
I am interested in any comments or suggestions.
Scott
zr1pete
Florida
Jascot, How fast do you tow? I have a 36 ft. Cedar Creek at about the same weight. I only make to about 64mph and fuel mileage here in flat Florida is 13.5 w/o air cond. and 12.8 with air cond....
whats your truck...is it stick/auto, what rear-end gearing, DRW or SRW, cruise on or off, a/c on or off.
towing 7-8k ive seen range anywhere from 12mpg to high 15's...its
all in how fast im goin for me...
acjjkamp
Blitz and Harley
Sacramento, Ca
we ave 8-9, with the best of 11 mpg, pulling 12.5k TH TT, ave spd 62, auto, SRW, 3.73, 4x4, AC on, no mods, rolling hills with some steep climbs.
with the 26' gn horse trailer, I get 9-10... with the 26' tagalong camper, I can do 13..
depends on how much weight, how aero the trailer is, trailer tire condition/construction, etc...
jascot
Fuel mileage
OK, my truck is a 2004 super duty, 6.0, 4X4, 3.73 ratio, w/ A/C on running 75mph, I have also tried towing at 68mph still no change. Seems that no matter what I do mileage does not change.
Maxtor
Redding
Hello Scott;
The only time that I have had to pull my trailer is 15.8 mpg. I get between 18.5 and 18.8 empty. My trailer is about 6000 lbs. I have a late model 06 (April) with manual trans and 3.73 gears. Everything is stock, from the factory. I cruise at 70 mph empty with cruise control, I do not jack rabbit start from a stop sign, and keep 70 psi in the tires. Here the chp keep a close watch on trucks pulling trailers, so when I pulled my trailer it was at 60-65 mph. Since the speed limit is 55 most of my pulling was at 60. 70 mph is about 1950 rpm and 60 mph is around 1700 rpm. So going up hills, I speed up to 65 so I don't lug the engine or down shift to 5th gear and climb the hill at 2000 rpm.
Wood County Tx
one more time we get 11 solid towing at 75 ish
TOTAL GALLONS
1,483.43
TOTAL PAID
3845.70
CURRENT MILEAGE
21,888.00
$ PER MILE
0.18
GALLONS PER MILE
14.76
AVG PER GAL
2.59
thats life time with everything combined right from my anal spreadsheet
TOTAL GALLONS
1,483.43
TOTAL PAID
3845.70
CURRENT MILEAGE
21,888.00
$ PER MILE
0.18
GALLONS PER MILE
14.76
AVG PER GAL
2.59
i bet you had to buy new batteries for calc. to do that math robert:roflmao :roflmao
