* Fuel Leak *
where would i buy these o rings, and how do i go about removing the valve?
Just remove the four torx head screws that hold it on and it will come right out. Get the 1/2x1/4 o-rings from caterpillar or anywhere you can find Viton o-rings. The viton are rated for fuel as where standard hardware store o-rings may break down in time.
smokin joe
Smokin.....
Fox Valley, Wi
Did you get it changed out?
Yes I did. It wasnt that bad. The only problem is I still see a small leak. The hose the guy gave me said it would work but I have my doubts. I think it needs to be a special type of hose not just fuel injection hose. That hose isnt easy to put on either.
Thanks
1064rg
ks
I got some 202 orings on ebay for like just $3. And IIRC 3/8 hose from local parts store.
hheynow
Señor Aceite de Soja
Northern California
What are the 202 o-rings for ?
and what is IIRC Hose?
Sorry for being so stupid:dizzy
The two 202 o-rings fit between the drain tube and the filter bowl. LOOK AT THE ABOVE PHOTO LINK. This is where many see leaks.
IIRC = if I recall correctly...and yes it is a 3/8" ID hose for the drain.
Jriltex
