TexasExcursion
GOD Bless America!
I've read all the posts on front hubs, but I'm looking for something different.
I had the X into the dealership today to get things checked out before RVing season starts up. They called and said the front hubs were frozen solid, couldn't budge them for anything. $700 to replace them, $550 of that being parts.
They said these hubs usually freeze up from inactivity. Well, I use my 4WD at least 2-3 times per month, not necessarily because I need 4WD, but because I know the system will work better if it's exercised often. To install the Oilguard system on my truck yesterday, I put it in 4Low and crept up on ramps (one ramp in front of each wheel). I put it in 4low so it'll go up nice and easy without much throttle required. I guess what I'm saying is that the 4WD worked yesterday, so how could the hubs be frozen today? Did something else happen with them? Should I check something else?
I like the dealer I go to, but sometimes they "miss" a few things (this site has come in handy several times). I told them not to do anything to the hubs for now cause I'm looking into an aftermarket brand versus Ford stuff, but first I want to make sure they need replacing.
FWIW, I always leave the front hubs in "auto." I liked Crumm's explanation of how the front auto/lock hubs work: "auto" if you've got room to roll to engage 4WD, "lock" if you're stuck and need to engage without rolling. I've never moved the hubs out of "auto."
