kju
I have a 2003 f250 superduty cc 4x4 powerstroke w/ torqshift transmission - It has 37,700 miles on it and now when i start it up and drive it for 10 minutes the Check Gauges light comes on and the transmission temp gauge will jump all the way to Hot and the tow/haul light will blink on/off for about a minute,then the temp gauge goes back to normal,the tow/haul light quits flashing and the check gauges light goes out and everything is normal.Shifts fine,oil looks good. It has done this 2 times in the last 500 miles. Anyone else experience this before ?? Any info. would be appreciated ?? Thank you, Kju
