Hey Blue. Thanks for the offer. I've flown into your airport for dinner at your mexican restuarant several times. Here is an update:
I've replaced both batteries since one of them were bad and the other was questionable. Still engine still hesitated and was reluctant to drive just 3 or 4 miles from the house. It would run fine and then all of a sudden, would run like it was on 7 cylinders and then it would return to normal. So I decided to continue to change the fuel filters.
After I changed the fuel filters, it started and idled for about a minute or two before it started to run rough and then stalled. Refusing to start. What else should I check or try before I call the dealership to have the truck picked up to be serviced under the 100k warranty. FYI, I'm currently at 56k miles. So I would doubt the fuel pump would give out under 100k. Appreciate any wisdom. Cheers, Mike
Update:
Took her into the dealership and will update as to what they find. Hopefully not my wallet!
