Excursion & Dualie 4 Sale at local dealer.
The owner spent all that coin on the suspension,wheels,diff cover,etc but slacked off and put TKO's on it:lmao
Ive put over 250,000 miles on TKO's (different sets obviously) and have yet to have my first flat. I get in some pretty ugly driving conditions off road here in Wyoming too, places you simply cant afford for a tire to fail.
55,000 on the first set of BFG's
50,000 on the second, could have put on more
40,000 on the third, but then I bought the harley wheels and couldnt use them anymore.
BTW, I asked what the bottom line was on the EX, the owner said it had to bring at least 38,000.
Also found out today, that this EX was originally owned in the Pensacola, FL area.
So its a good southern owned vehicle, that would explain why its so clean underneath.
OASIS RESULT:
1FMSU43P05EB13160
12/15/2007
09:34:19
FCXWS447
© Copyright 2002-2007 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2005 EXCURSION BODY STYLE
LIMITED 4 DR 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
5L110N0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 07-16-01
BEFORE REPLACING 6.0L CYLINDER HEAD GASKETS REFER TO 07-21-05
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB 07-05-04
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
07/22/2005 BUILD DATE
10/14/2004 SALE MILEAGE
00033
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
05/30/2007
DEALER: Cook-Whitehead Ford, Inc.
WARRANTY CLAIM NUMBER: 010003 ODOMETER: 024171M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 9229B GASKET CARB FUEL INL 001 6007D D8 FAILED GASKET/SEAL
000 9527A2T
24173 FAILED SEAL .8 DIAG OIL LEAK, R&I CAMSHAFT POSITION SENSOR, REPLACE O -RINGS, RETEST
05/30/2007
LABOR OP
CONDITION CODE
CONDITION DESC
9E926 BODY ASY-AIR CHARGE 000 6005F 82 FREIGHT/POSTAGE/MAINTENANCE
000 6005F1
000 6005F2
000 6005F6
000 6005F8
000 6005F9
24177 OPERATES AS ENGINEERED AT THIS TIME PERFORM DIAG, TEST DRIVE, MONITOR PIDS, 25 PSI BOOST, CUSTOMER HAS SUSPENSION LIFT KIT 295-75R16 TIRES, ADJUS TABLE AIR SHOCKS, & AIR OVERLOAD SPRINGS INSTALLED
05/30/2007
LABOR OP
CONDITION CODE
CONDITION DESC
19850 EVAP ASY-A/C ATC 000 19700D 49 CONTAMINATED/FOREIGN
24177 .6 PERF TST,CK OK,OPERATING AS DESIGNED
W4RLR
High Tech Hillbilly
Sewanee, TN
Don't you just hate it when your dealer rat finks you to Ford as evidenced by the OASIS report citing the lift kit and the other goodies?
All the better to deny a warranty claim later, I guess. :rant
RR-
the interesting part is that NOW its in the "permanent file"
so even if you put it back to stock someone could find reason
to deny warranty work.
Big K
SDD.com Hacker/Admin
Dallas, Texas
Yeap, I saw that ! :rant
Jriltex
