Engine shaking
Chiwape
Alb/nm
Hi, I have a 2006 f250 6.0L. I have had this problem happen twice to me. I was on the highway and truck began shaking badly. At first thought I blew a tire I finally got It stop. Wasn't any tires. Got back in the truck and ran fine. I thought it was bad diesel. It did it to me again but I didn't stop and it went away. Any one have suggestions what it can be? The shaking gets pretty bad. Any help thanks.
2 Stroker
Warren/Oregon
My understanding of this, it's call the Death Wobble if you are running factory tires that are not 10 ply this will happen because the stock tires do not have the side wall to hold the truck because of the flex but if they are 10 ply then look here What WOBBLE? also you could look at this for repairs got this from another forum hope it helps:dunno
Part Numbers for New Ford Steering Stabilizer....
FMC 7C3Z 3E652 C UPDATED BRACKET $33.40
FMC 8C3Z 3E651 E UPDATED DAMPER ASSEMBLY $81.99
FMC W520415 S301 BOLT $3.14
FMC W706196 S439 BOLT $6.72
LABOR $207.90 Should have done this myself!
So far, this seems to have fixed the issue. I do notice a short quick wobble but nothing like before.
Ford should be paying the bill for this fix since they know its a problem!!!!!!!! Why else would they update the part
2 stroker:coffee
FlorWhitfe
