I have a friend that is part owner of a lube shop. They did an oil change on a 06 superduty powerstroke. Their bulk oil system switched from liters to quarts somehow and overfilled the engine. Not knowing that this happened, they started the truck and saw oil coming out of the filter. They turned off the truck and checked the level. It was way over full. So they completely drained the oil and started over with the right amount. The customer drove off. A few minutes later the customer returned complaining of blue smoke coming from the exhaust. Now my friend would like to know if the engine is roasted. Ford told her to replace the air cleaner and clean the air cleaner box then have the customer drive on the highway to burn off the rest.
What do you think?
What do you think?
