Our truck just ticked off 7500 miles. This is the second oil change, because I wanted the first change to be at about 2,500 miles.
This change I only put in 14 qts. and it filled the dip stick to the full mark. At the bottom of the radiator, there are cooler lines that go into the manual transmissions bellhousing. My guess is that they go to the back of the block and feed into the oil system. This would explain where the other quart of oil that did not drain is. I am going to purchase a service manual for the truck so I will know for sure.
Anyone know for sure on a manual trans truck?
