engine lopes on start up
muddinmike
boise id
yep had lope issue and rough idle prior to HPX. I did the HPX because i searched around here and lots of people said the HPX was the cure :rolleyes: it didnt help at all and if anything the idle is even rougher now. Ive ran the truck hard(towing 12k 5th wheel) for 2500 miles sense i put it on a couple weeks ago so it must not be trapped air. I'll try a oil change again with the lighter oil but i think its something else. I changed the fuel filter too just in case. Truck has 102000 miles FYI.
Try 5W40 oil. It is the first number in oil that is the cold number protection. I switched and it cured my lope. I use Rotella T 5W40. Wal Mart has this oil.
muddinmike
boise id
well now the turd sprung a major oil leak. leaves a trail behind it and about 40 drops in the amount of time you come to a stop and shut the turd off. :rant
looks like its coming off the driver top side of the block somewhere. time to powers wash the oily pig up and find where its coming from :watchout
FlorWhitfe
