Engine backpressure is usually related to boost pressure. There is a math ratio for calculating how much engine backpressure is being created for a certain leel of boost.
At idle, it should be very low, however I think the sensor that read backpressure is calibrated for 14.7psi at sea level. Which means, even with the engine OFF, it will still read 14.7 psi.
