Electrical question
indycecil
Indianapolis IN
Can anyone tell me why my dome light quit working. All the instrument lights still work, and reading lights still work with the switch. The dome light, cargo light (on back of cab), and the lights on the running boards quit working a couple of weeks ago.
whatabudro
Launched
Try all four doors and see if its just one door that has the problem.
Fire1
Certified Diesel Driver
I had similar issues last year. The fuse was LOOSE and would only make contact intermittently. So check the fuse first.
indycecil
Indianapolis IN
I checked the fuse schematic and find a fuse for the interior lights just a relay and I don't know how to check to see if it is ad.
whatabudro
Launched
You can buy a new relay (maybe $10) or jump it out if you know which contacts to jump. If you have power there and relay is good then its probably the GEM. You may also have a bad battery saver relay.
Fire1
I believe there other relays that can be swapped to check that issue. I believe I tried that also.
Got Diesel
Engineering College Boy
Missouri
How about the bulb it's self. Not to be smart or anything but it could be overlooked.
Fire1
I find it highy improbable that all these bulbs burnt out simultaneously, but I suppose that it is possible.:dunno
FlorWhitfe
