Electrical 911
stonework
Houston, Texas
hello all
I greatly appreciate any help!
I tried to mount the overhead dome light in my 04 F250 6.0 4x4. I apparently hit an electrical instead of the hole and now do not have any power windows, radio, or any gauges on the instrument cluster.
Thanks again!
groundhawg
Indiana
Did you check the fuse? I'm not sure what all it would cover, but that sounds like the probable culpret.
First thing though, take the light back down and check for the wire/wires that were nipped. Get them insulated once again before you change out the fuse.
check the fuses...and dont bet that you can just VISUALLY confirm a blown fuse...you might have to put a meter 'cross it.
these little buggers are hard to see when / if theyre blown.
now i replace blown fuses w/ one of these (lights up when blown) !
FlorWhitfe
