egr valve
bob68vw
peaster, tx
took it out today and of course all gummed up, so we went custom cut it off welded gear just to be safe put it back in. :thumbs
fordoor
SDD Member
N. Calif.
I've never heard of this one before. Can you plug in harness or does it trigger the C.E.L. ?
Zmann ARGH
AZ
03 throws a code but not a cel later years throw a cel
I was going to weld mind but inside on the valve area so prying eyes wont pick up on it
bob68vw
peaster, tx
it is welded inside, the top and plug in are still there, just removed the valve since not used anymore.
Zmann ARGH
AZ
so you removed the valve ?? did u do the internal plug ?
Zmann ARGH
AZ
you need to have isolation between the exhaust and intake ..
