Question early vs. late injectors, can you mix?
Eubee
Mount Pleasant, MI 48858
I have been serching for various things tonight, and came across the following site and page 6.0L Powerstroke Injectors . Basically, they claim that an injector with white plastic is an early version, and an injector with black plastic is a late version. I have a mixture of both black and white injectors in my engine (not my doing, I bought it that way). Anybody know if this can cause problems?
Thanks for any info.
My Ford Service DVD makes no distinction of the two injectors. It does not address this issue.
Eubee
Sent a message to the site's webmaster. They replied back saying that it will not hurt anything. The later version has a coating on a/some internal part(s) to help with lifespan; that is the only difference.
AH!! It does say that there is a difference with the Early or Later injectors, but again it does not say what it is... Good to know.
bismic1
Ford states NOT to mix them.
3C3Z-9E527-AA (Original C91 injector) was replaced in 2003 with part number 3C3Z-9E527-ABRM (C94) and then later with 3C3Z-9E527-AE (C95). These part numbers were for engines built before 9/22/03. The latest injector number is 4C3Z-9E527-AA (C2 or C92) for engines built after 9/22/03 . The difference between original C94 & new C95 was internal change to clevis. Had to do with plunger suffering from side loading which then causes raw fuel to flood and enter the engine oil crankcase. Design improvements aimed at preventing scuffing.
There are no physical fitment differences between the injectors, but best not to intermingle them.
Along with the clevis re-design mentioned above (which helps prevent scuffing) one additional change below:
Change in JANUARY 2004 from the 2003 design:
DLC (Diamond Like Carbon) Coated Plunger
• The injector plunger has had a DLC coating applied to it
• The coating will further increase the robustness of the injector against poor fuel quality/water intrusion and will reduce the risk of internal scuffing.
Note: The two injectors have different operating characteristics and DLC injectors can not be interchanged with non DLC injectors.
Installing the incorrect injector could cause Erratic or rough engine operation.
http://turbodieselforums.com/downloads/6.0L 2004 Book.pdf
page 27 of the presentation in the link above
