driveshaft
melmount
greensboro nc
has anyone, removed the 2 piece shaft and had a custom one piece made?
can this be done? I am sure its possible, but would it work?
no issues with mine now, but seems to me, that it would be quieter and more efficient one piece?
any thoughts??
keanoknick
Big Stroker
Cowtown TEXAS
Lots of people have done it, I can't give you much more info though, sorry.
It is on my to do list :rolleyes:
i suspect the problem has more to do w/ ANGLE and ground clearance
more than anything.
melmount
greensboro nc
you would think less angle, more at the trans but less total, larger angle from the middle down??
i 'spose but the amount of drive shaft thats exposed (using
a one piece) is gonna be greater...
hell if youre gonna change it out go carbon fiber replacement...
melmount
greensboro nc
can i barrow the funds?
never heard of a carbon driveshaft?
the new dodge even 4 door long beds use a one piece aluminum
i dont off road, so clearance wont matter, unless it looks stupid, i dont think you would see it.
where can i look at carbon ones?
were you kidding?
no im not kidding...carbon fiber is the hot tip in racing & is a
great product for dropping weight & buidling strong products.
'course youre issue is that you truck weights close to 8000lbs !
and unless youre building a RACE truck its probably a stupid thing
to consider.
melmount
greensboro nc
nope not racing it, was just wondering on a one piece shaft, my dodge 4 door long bed had a 2 piece and it made a lot of noise with the carrier bearing etc, one piece i like better. i saw the new dodge uses a one piece, I figure if they can do it i can do it,
where would i check into that?
Kleetus
Butler PA
Local drive line shop... many places ought to be able to hook you up. I almost did it in mine, and I might still.
FlorWhitfe
