Question Drive train problems
moeller96
St Paul MN
I could use some advice. I have an 01 f350 long box crew cab. Last summer I had a u-joint replaced and the guy said he thought my tail shaft was too long. I have replaced 4 u- joints over the past 4 years and now my truck won't shift out of first gear. The entire truck is totally stock, and I do haul a heavy 5 th wheel fairly often. Could the shafts be putting too much pressure on the back of the tranny causing this issue or do you think the tranny is wrecked. I have no idea how my drive shaft could become too long. Any help would be greatly appreciated. Thank You
If the drive shaft is stock, NO it is not too long. There is a slip joint at the tail shaft, at the end of the tranny. If it was tight and jammed up to the tranny, you would hear a thud on every bump. The tranny has a separate problem not related to the drive shaft. Have you checked the tranny fluid, and does it smell burned? A local tranny shop needs to check it out.
moeller96
St Paul MN
Thanks Dave, the tranny fluid is normal and everything electrically checks out with it. From what I've heard the transmissions in these is trucks seem to be a little weak, so it may have to be rebuilt. I haven't looked at the shaft myself but my guy swears to me that all the play is used up on the slip joints between the tranny and the rear case. He says he has never seen this before and seems to be very knowledgable. Even with the truck on a lift he had to pry the u-joints out cause there was no play in the shaft. I'm going to let him cut about 1.5 inches off the shaft and have it balanced. The truck seemed to shift just fine when on the lift. So we will see just wondering if anyone has ever seen anything like this before
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Check your rear end where it bolts to the springs. If it has worked loose it may have shifted ahead. There is a centering bolt that should hold it in place but I have seen them break. Just doesn't seem right that your drive shaft grew.
KRISTOLSON
Thief River Falls, MN
Yeah thats very strange. I would def check all the mounts for tranny, tcase, and rearend to make sure nothing has shifted.
trackspeeder
Stone Crusher
North Branford CT
The tranny needs to be rebuilt. Most likely a failed mechanical diode. This was Fords attempt to upgrade the sprag. It failed. This part is an 01 only part.
I wouldn't be cutting that drive sheft just yet. Take it to another shop and let them look it over.
get the trans fixed first.. if it's got anywhere near 150k on it, it's due.. then worry about the driveshaft
I broke a rear spring center bolt on my '72 F-250. It would shift every time you put a force on the axle, either braking or accelerating. You would need to correct with the steering wheel.
Dave :dunno
TacoCat
