rgdillon said:
Joe -
Are you running this through the center hole of the existing weather stripping?
Ron
Hi Ron, Yes. If you run yer finger down the weather strip yul feel the collapsable part (it's open at the top & bottome) that is >supposed to< seal against the door when it's closed. That seal is prolly marginal, at best. Yul also feel, a 6 or 8 inch piece of cording that Ford put in, in the area of the Door Latch.
What I did: poked a piece of wire thru the strip, at the top of Fords piece, shoved it UP and out of the top, taped the foam cording to it, pulled it back down thru, til it bottomed out at Fords piece. Same from the bottom of Fords piece, up. The weather stip will re-seal the holes you poked... you can't even see where you did it.
Nice tight seal, from Top to Bottom... MORE Quiet inside.
JOE
