Door lock problem
bobby
Yulee Florida
My , 2003 door locks / lock but will not unlock via the door switchs, I do not have keyless entry. I've taken the drivers side accuator out and did the foil trick thing but it still doesn't work. also checked the fuse anyone got any ideas :dunno. Will one bad accuator cause all not to work?????
There seem to be many things that will cause them to malfunction. I recently went through this on my OBS. Mine ended up being a short where the wires go into the left rear door and the short fried the remote entry module. On yours I would start by closely inspecting the wiring between the cab and doors. One broken wire in there can make the whole system malfunction.
Butch Cassidy
Chelmsford, Mass
bobby,
Check out the wiring connections - for tightness, corrosion. I ran into a simular problem w/ my door locks - turned out to be a loose switch connector. I cleaned up the connector contacts, made sure I had a good solid connection upon reassembly and all is well.
Butch cassidy
TacoCat
