mobey: sorry, the 'shut off' that was in the yard was ummmm frozen in the ground. pushed down about six inches and bent at a 45 angle. hence the easier method of 'brake' in...
f350: i could hit it w/ a rock...
What am I not understanding here? Water wont freeze at 50°, so the furnace must have quit totally?
the water line that runs inbetween the ceiling of the lower level and what is the floor of the upper level that runs to the outside front water facet BROKE inside the wall
Then it isnt a furnace setting that caused the failure, its poor insulation.Yes, but in a wall with a draft, bad insulation spot, it will freeze no problem, specially with a little breeze![]()
