got it from planet ford on I-45 and Louetta it just felt like it wasent cooling enough and i asked to get it checked.. salesman said some was added. i even bought a vent thermometer and it was working fine all summer last year...i checked my fuse under the dash and its good too. when turning the A/C on is there a noticeable noise from the cab? the a/c compressor coming on or do i have to have someone inside turning it on while i stand outside listening to it?
if youre noticing a drop in the ablity to COOL then
its probably got SOME issue <leak down etc>
charging the system is gonna be a TEMPORARY
solution...it might seem cheaper to to this <repeatedly>
but eventually youll be buying some really expensive parts
instead of having just fixed the leak.
you need to put some die in the system and use a freon/gas
"sniffer" to determine where the leak is so you can FIX it.
imo this is a DIY job and you can save ALOT of money doing it
yourself....autozone loans will loan you the tools (except the freon
sniffer) to do the job PROPERLY & you can buy the parts & die
from 'em too.
we did a friends suburban last year....a/c shop wanted 1400
to replace the leaking compressor, evac. the system and recharge it...
we did it for less tha 350 bucks !
