Question Cold
BigDogDaddy
Newberg/Oregon/USA
Ok so it has gotten that winter chill going 18 last night and truck started kinda rough in the AM...
My meter is telling me that my block heater is open and it is for sure not doing any good to leave plugged in for sevral hours.......
My Question is is it fused or has my heater rod broken????:dunno
IHC Power
STOCK STROKE
Walpole Mass
block heater
Your in luck, I just changes mine after it failed last year, the meter should read 14 ohms across the two terminals, you just need to replace it. a cord wouldn't be a bad idea either they get stressed at the plug and usually a wire breaks, they cost about $70 from the dealer. make sure you burp the cooling system after you change the block heater too, air pockets can kill a diesel engine, remove cap and run truck till warm. Keep trucking.
and don't forget to unplug it before starting the engine in the morning..
that's what kills most of them.. a rush of cold coolant burns it out.
When it's quiet near my truck, I can hear the block heater working.. kindofa Hsss.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I've never had an issue with the heater element. But the cord has given me problems on about 4 occasions.
BigDogDaddy
Newberg/Oregon/USA
Thanks guys not what I wanted to hear but never is.........
Heading out to check the cord and plug but have my dbouts, only because it popped a breaker last year but I never needed it after that so I wasnt sure....
just put a new alt in yesterday due to the COLD sure weeds out the weak stuff!!!
Thanks again
Ron
BigDogDaddy
Newberg/Oregon/USA
Thanks again
Looks like I need a new cord........
Now just to find one,but its better than doing the block heater too....
Stay warm Ron
TacoCat
