Question Cold weather, How do you start your 7.3?
Bbasso
Upstate S.C.
I have access to a 110 outlet, but haven't used it yet. The temps haven't been below 35 when I start the Van (w/ the 7.3).
It's takes an extra second or two to kick over since it's been under 50 deg.... I'm thinking it's time to plug it in before turning the key.
I usually wait 10-15 mins before driving or until the temp guage reaches the lower part of the operating range.
So...
For everyone who has a 7.3 PowerStroke, what's your cold weather starting procedure?
And last, how long do you let it warm up?
Thanks, I'm sure this will be helpfull to all of us :sweet
tony4380
columbus, GA
hopefully not with a can of starting fluid! i dont have a 7.3 but i typically cycle the glow plugs twice.
35 ain't bad..
it was 9 degrees out when I left work tonight..
I don't have access to a plug..
I worked 13 hours..
oh yeah.. she put up a fuss...
dpantazis
#12
under the cheddar curtain
big red was not happy today. -4 in the am. she gave it the college try but no luck. i have not switched over to winter oil yet either- still running summer oil.
if its plugged in for a good 2-3 hours, she will fire and cough. 4+ and she is as happy as can be.
So...
Here's my SOP*
Temps in the 30's or below, plug it in for at least, 2 hours. (more time if colder)
I Cycle the WTS 2 times.
I [Don't step on the throttle].. start it.
I Let it high idle (use the EBPV at times)'til the temp neddle moves [Off] the cold peg.
Go 'bout my bidness. It may Buck'n Snort at a Stop sign or two (6 speed).. but HEY.. It's a Dezel.. They're ALL.. Cold Blooded.
*I run 5W40, full syn, year 'round.
Akpaul
Wasilla,Ak.
2000 F-350 I run rotella syn. and it gets kinda cold here in Alaska if I have access I plug in when temps. get below 20, but with the syn. oil it'll fire right up after sitting in -25 degree weather for 2 weeks. Cycle the glow plugs twice and go for it, let her warm for several minutes and go for it.
1 cycle heating up the plugs in the 30's and down with the block heater on for 2-3 hours,cranks right up,even better with the new Denso big daddy starter:D
trackspeeder
Stone Crusher
North Branford CT
I have two starting methods for the 7.3. Old and new :D
The new 7.3 (PSD). Cycle the plugs then let her rip. If it's really cold the block heater is plugged in for 3 hours.;tu
The old 7.3.(IDI). Cycle the plugs a couple of times. Slam the go pedal to the floor.Hope it starts.:lmao:lmao
hawkdriver
Lake Martin Alabama
Down here in Lower Alabama it has been down in the low 30's in the AM's. If I know it is going to be below 35 I drive the truck (usually ride the Buell every opportunity) and I plug it in at about 11 and start it at 0530. Starts right up when the wait light goes off. I let it idle for about 3-5 minutes and baby it for a mile or so and then I'm going 70 mph. It is noisier when this cold so I take it easy on her.
Bbasso
Upstate S.C.
"Cycle the plugs", what does that do compared to just turning the key and waiting for the light to go off?
TacoCat
