cold start hesitation
1ofakindgt
akron ohio
When I start the truck and pull away without a warm up it sounds like the truck is hesitating but its not. It also makes a weird grinding noise maybe i cant explain it. Once its warmed up goes away. Any idea.
What Dave said. ;tu It's a Diesel.
Head (Combustion) temps aren't high enough yet to make good power.
Fan clutch is engaged.. (as it should be) making a wrrrring sound (?)
fordfury
redneck punk
idaho
sounds like your warm up valve on your turbo is on. goes away when you give it more throttle
TacoCat
