jrdrag
Hey Guys,
We just bought a 97 PSD 4x4 with a E4OD. When you are driving down the road and let off the pedal you here a clunking noise. We tought it was a tranny mount but it checked out okay. It also does the same thing when you put it in reverse. It almost seems worse. But it only does it when you first put it in gear. If you put it in gear, it will clunk, but if you hold the brake after it clunks and give it throttle, it won't do it anymore. Same is true for forward gears.
Look for some advice!
Caleb Peterson
3CMotorsports.com
Caleb Peterson
3CMotorsports.com
