Chasing wiring
goldhilljoe
S W Oregon
I may have mave missed your point, could it be the IDLE Validation switch you are seeing??/posting about? :dunno
Mine is a Centurion conversion so that cluster of wires is what Centurion did, There are some areas that they did a very good job of routing wires soldering connections & splices, wire looming and other improvement and upgrades, but as you can see there are some that they didn't just drop it but threw it down.
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
Ok this is driving me nuts... I checked the wiring and had noted on the way the guy had hooked it up... It had constant power and the ground was running through the switch, I was a little ???? so I flopped it around so it will be a constant ground and have the power through the switch but nothing is happening, notings moving no mater what I do.. I hooked up my Multi Meter and Im getting power to the connector... Any insight or a write up on this so I can go through it
W4RLR
High Tech Hillbilly
Sewanee, TN
It's like the guy never heard of heat shrink tubing and tie wrap. He should be found, taken out and flogged mercilessly with the rats nest of wiring he put in that truck! :2c
MUDWHISTLE
Diesel Lover
oregon
Yeah and then raped with a bottle rocket.
Ricksofla
