Chasing wiring
Not knowing how it is wired I would have a friend push the button while I watched the valve to see what it does. But I would assume its a close on contact made button so... yeah, let off the accelerator and push the button.
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
How couls you see if it was opening or closing, its insde the housing isnt it Or are you talking about pulling off the ducting and looking
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
95_stroker said:
The linkage comes out of the turbo pedestal, you'll see it moving.
I guess I will just have to wait and take another look at it because I dont recall seeing linkage
Heres where you will see the linkage hook up at in the left side of the pic, the connector in the right side of the pic is where your switch is wired to.
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
Thanks Man you rock
Now if I can only figure out the other switch that I have
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
Well I was checking it out, found out that the switch is bad, so I will be swapping that out a better type of switch for the setup
Here's a picture of the rat's nest of wiring under my dash that I got to figure out where things went to and that doesn't include the auxillary fuse& relay panel for the switch panel in the overhead console.
I feel for you in tracing wires and trying to figure out what goes where that someone else did.
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
By looking at all the Aux wiring thats in the truck, The guy did a very good job in routing and placment of everything, The factory wiring looks more like a nest than anything else
Ricksofla
