Hoss 350
My GSP, Dutch
Getting started tomorrow
My plan of attack on the truck goes something like this...
1.) drop front and rear drive lines
2.) drain t-case and tranny fluid
3.) disconnect T-cooler lines and clutch/t-case linkage
4.) Remove shifter handle
5.) Support trans with jack.
6.) remove cross member
7.) Remove bell-housing bolts
8.) drop trans
9.) Remove shifter fork and T-out bearing
10.) Replace fork and T-out bearing
11.) remove pressure plate, disc and flywheel
12.) reinstall new flywheel, disc, pressure plate with alignment tool in place, torque bolts
13.) Jack tranny into place, bolt up bellhousing
14.) replace crossmember
15.) remove jack
16.) reconnect linkage, cooler lines, shifter
17.) put fluid in trans/t-case
18.) put drive lines back on.
Drive the truck. Can you see if I forgot anything? I think I already see something, probably have to drop the starter motor...
How do you break in a clutch? It has been years since I've done this, and I cannot remember. Slip it lots? Not slip it at all? Drive it like normal?
8.) drop trans
15.) remove jack
