twt
Has anyone had camshaft float?? My truck misses, runs , misses, runs. I have heard that the camshaft can wear a plate & move to the rear of the block, & the cps looses the signal . Have you had this problem & how do you check how much the shaft is moving -(the gear has lobes on it ). Anyone know what the fix is? Been chasing this problem for a while, new uvc wires,cps's,idm,injectors,fuel filters & fuel pressure is good at wot.?? HELP
