Question Camshaft float?
Dogman
tampa,FL
twt, what tuner did you use?? I had a guy come in some time ago with a problem sounding like yours, and the tuner corrupted the computor bad software in the tuner and nothing could fix it but a new one. My 04 dropped a cylinder on my 6.0. It was from a corrupted tuner to. I would try taking .0020 off the cps and see if that fixs it. You may beable to get the computor reflashed and try that too. I know that some of the Bump to Bump stores and Parts Depot stores can have the computor flashed.
twt
Glasgow ,Ky
I put in a DP tuner & then used a TS from Swamps to see if the problem would go away - no. I am going to order 2 new cps sensors & take .001 off 1 to see if it gets better. I have talked to a buddy at work & am going to put some plastic shim on the end of a cps to see how much clearance I do have. I am also going to check my batterys one more time.
