bent rod or fuel/timing knock???
94f450sd
certified nutjob
plymouth,ma
now that shes running again it runs like it used to but nowhas a loud knock to it.if i goose it the knock goes away untill it reachs idle speed again.same thing while driving.if im up to cruisespeed i can hear it.if i get on it a little it goes away and comes back when the RPMs level off.it doesnt sound like a rod knocking,KNOCKKNOCKKNOCKKNOCKKNOCK.its more of a KNOCK KNOCK KNOCK KNOCK.and while cruising normal around town it has some smoke that it didnt have before.
what do you guys think?i did a buzz and CCT and it passed both.just want a few ideas before icall bean again
JOAT
I Found Nemo!
The West Coast
Loud clanging knock at idle that goes away when you goose it is often a cracked flexplate. Pull the inspection plate and watch it at idle. Will often look wobbly. Also one I saw you could see a rust colored powder radiating from the center on the flexplate. Common on early trucks with the thinner flexplate.
If you have a way to record it post the sound.
94f450sd
certified nutjob
plymouth,ma
i probably should have posted this in the other thread.but this just started yesterday when i got my replacement injector and installed it.the engine didnt hydrolock or anything.
JOAT
I Found Nemo!
The West Coast
Gotcha, been AWOL a few days but checked your past posts. Possible the injector is still a problem. Did you check for bent push rods while you were in there?
94f450sd
certified nutjob
plymouth,ma
no cuz the truck ran fine just had a skip to it.now it runs perfect with no skip but now has that knock.:confused:
roosterdiesel
Earl needs B100
Amarillo,TX
Could it be air in the oil rails not worked out yet?:dunno
I know when I put a mechancal HPOP gauge on my truck it got some air in there and was louder for a bit.
Hope it's not a rod.:eek:
94f450sd
certified nutjob
plymouth,ma
dont know.ive been deiving it,so all the air should be out.ive been beating the crap out of it too and it hasnt gotten any louder or quieter.i got a video with the noise but for some reason putfile.com wont upload it.
Tbar
SDD STAFF/Moderator
I am no expert on the OBS trucks but to me it sounds pretty good. At worst it sounds like my 99 with air in the fuel lines. :dunno
On edit: you might try changing the oil as you may have cross contaminated it with fuel when you replaced the injectors.
Tbar
TacoCat
