bent rod or fuel/timing knock???
94f450sd
certified nutjob
plymouth,ma
hey mark,glad to see you made it!:sweet hope you stay for a while and find the air much cleaner here.
buti didnt have that knock before the bad injector
Frankenstien
Frankestien
South Prairie Wa.
Yes I hear your knock, that sounds similar to what the LL#8 was supposed to fix, My truck did that same knock until the injector was replaced.
MUDWHISTLE
Diesel Lover
oregon
wonder if you have another injector starting to go bad. Might explain the smoke.
94f450sd
certified nutjob
plymouth,ma
my fuel milage has been cut almost in half.i used to use 1/8 tank to get to my shop now im using a 1/4 :eek: :eek: it passes the buzz and cct everytime.ive run these test about 30 times since i got it running again.i just dont want to cal and be a pain in beans ass if i dont have too.
JOAT
I Found Nemo!
The West Coast
I'd call Bean. My had an intermittant knock like that when the poppet screw was loose, but I had a rough idle too and loss of low end power. Since yours started this after the injector problem I'd say that is a good place to start. Maybe Bean has a loaner injector you could swap in and test.
Ricksofla
