Battery light coming on
dieselfoot
Ham Lake,mn
The battery light started coming on this summer. The length of time it stays on varies. Truck starts fine , lights and every thing are bright and work fine. The batteries were both changed this spring. Light never came on before the new batteries and didn,t start coming on until a month after new batteries. Just looking for ideas to start checking .
First off.. check & clean & tighten the battery terminals REAL good. Then test the running voltage.. should be 14.5 or so. after that (?) being 4/5 years old ... test, or have, the Alternator tested.
Might also have EACH battery independently Load Tested, to be sure they are BOTH in equal condition... to each other.
Man I wish I had a dollar for eveytime I've heard you say that:lmao
x2
;):lmao And it won't be the Last :lmao:lmao
I wish had a dollar for every time I'v been able to save sumbuddy sum Big Repair Bucks.. by doing, or saying that......
Zmann ARGH
AZ
just FYI there is a huge load at start up with the glow plugs .. they stay on for up to 2 minutes ,, not in concert with the wait to start light .. after they go off most weak systems can bring the charge up // I would check it ll like suggested
scottu5
