Axle ?
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
OK im tryin to figure out witch axles my truck has under it, for the rear im thinkin dana 60 or 80 and front dana 50 maybe ? Owners manual isnt helpin much to clear the air...go figure F-350 drw with 4:10's gunna change oil in em and tryin to figure out witch oil 75-90 or 75-140? I plan on runnion amsoil
any help would be great?
any body runnin aftermarket diff covers? whats good?
Thanks a bunch
Neal
dboyw
Lancaster, PA
When I get home I 'll see what info I have around.
I run Amsoil Severe gear in the rear with a Mag-Hytec cover and I do like it. I check the dip stick once a year for lavels and shavings.
jpringle83
WA
Thanks a bunch
Neal
75-140w It's a Dana 80 more then likely it could be a Sterling 10.25/10.50 but both of those rear ends take the same oil. Don't know if you have a limited slip or not but you can buy the oil by the quart or gallon with it already in it. If you want to be sure go to www.ringpinion.com and enter your information and then match the look of your rear cover to the pictures on the site.
jpringle83
WA
is there a gasket for the cover or is it a silicone on cover?
Most of them have a paper type gasket which having used several tend to leak. It doesn't look like LubeLocker makes a gasket for the Dana 80 so get yourself some good black or blue silicone rtv. Both are oil and heat resistant.
