rsjohnsn
Hi all, I did the AIC mod on my truck where I installed a switch to idle the truck up to about 1100 rpm at idle. The mod has been working fine until the other day when I had it running for the AC and I was under the dash running some wires and pulled a wire off the switch. Now nothing works and there is no power to either wire. The only thing I can figure as that I shorted something out when I pulled the wire loose but I don't know where to look. Does anybody know where the wire gets its power from? Is it a fuse or circuit breaker and if so where would it be located.
Thanks
Scott
Thanks
Scott
