any other ATF synthetic that is Diesel approved?
Scar13
Little elm, tx
Looking for some darn ATF fluid that is Diesel approved and synthetic other then Mobil 1.
Everythign I am finding now says mercon V.
You will not find an ATF that is diesel approved. Transmissions do not use diesel. Sorry. :)
Scar13
Little elm, tx
Dave you know what I meant ;)
I will re-word for you HAHA!
Any other synthetic atf fluids for our trucks that are approved other then the mobil 1 NON mercron V ?
northshore
Northshore
Lake Havasu AZ/Loma Rica CA
I probably need a lesson in ATF, however isnt the mercron V a synthetic?
and Ford says not to use mecron V, right ?
so is Ford saying not to use a synthetic or is there something else that is the problem with mecron V?
It seems to me I heard that the synthetic fluid does something to the clutches.... ?? but thats probably a mistake.
Scar13
Little elm, tx
Someone will swing by and correct me I am sure.
its not the Synthetic, thats bad its the additives for the mercron V that will wear down the parts in your Auto Tranny.
GREGROB
MERCON V isn't required to have synthetic in it.
For a good Synth ATF you may want to try AMSOIL Torque Drive.
It does not carry the MERCON V rating, and is some very good fluid.
MERCON V can agitate the glue that the clutches are assembled with and cause them to come apart, obviously if the clutches defragment, clutch material will clog the Valve body, cooler, and everything else resulting in a toasted tranny.
BTW, first post. Looks like a cool site, glad to be here.
JimmyDee
God Bless America
Western Michigan
Welcome to this site. I think you will enjoy it here and it looks like your knowledge of the real reason for not using Mercon V, you will be an asset here as well.
Jim
