Waterproof
Okay, here is my issue. My truck died while idling when I was letting it warm up. Went to start it back up and the batteries were totally dead, now keep in mind it started up perfectly 15 minutes or so prior. I figured my alternator went out, pulled it out took it to the parts store and it tested bad. Replaced the alternator, charged the batteries up for a while from an external source, started the truck back up and it ran fine for about 10 minutes or so and died again. The exact same thing that it did prior to me replacing the old alternator with a new one. Called the parts store back up and had them re-test the original alternator which now tested good twice. Took the new alternator back to the parts house and put my old alternator back in the truck. Replaced the regulator plug with a new one per the parts house suggestion. Truck seemed to run okay for a while. Now here recently the truck started acting up again doing the exact same thing. Replaced the alternator AGAIN, replaced the batteries with Two brand new batteries, and guess what, it is still doing the same thing. My truck is out of warranty even though it only has 89,000 (thanks Ford for the 5 year time limit) and shy of putting a stick of dynamite under it, what should I check to see what else it could be?
