dieselpilot
I know this reads like a diesel tech 101 questions but is the air filter monitor a reliable means of determining the time to change the air filter or do you guys just change it out in a preventative maintenance fashion. Like every second oil change?
Also, and this is going to sound a bit naive, but at which end does the red indicator have to be at when it's time to change the filter, the firewall or the air filter housing itself. I've looked in the manual and it isn't very clear.
The reason I ask is that when I shut down I hear the air filter housing sucking air for several seconds after shutdown, or at least it sounds like it's coming from the air filter housing. It sounds like a vacuum cleaner running down after it's shut off.
Thanks for helping me out, again.
Bryan
Bryan
