Question Aftermarket Turbo
fordoor
SDD Member
N. Calif.
Wondering if I should replace the stock turbo w/ something else now that my warranty is up. What brand? I just want a turbo that doesn't hang up,coke up,rust up. Quicker spoolup would be quite welcome! Any of you have experience or info. w/ aftermarket units that really work and aren't problematic (direct replacement)?
kenholl
Its my side of the garage
McKinney, TX
Unless you have disposable cash on your hands, and not many do in this economy, I wouldn't fool with it until your factory turbo fails. Anything mechanical, whether your factory turbo or an after-market, is subject to failure at some point. Why open a can of worms?
My '04 6.0 w/80k miles has never hinted at a turbo problem. I'll deal with it when that day comes.
I second what Ken says. You won't improve on what you have, but you can change your driving habits. Get on it a bit more and that should keep the turbo from getting fowled up. Mine has 100,000 miles and has not coked up on me. I do get in it when I can, like getting on the freeway.
Dave :)
1956ford
Pre-Retired
Bentonville, Arkansas
I am looking at a Garrett GTP38R replacement turbo. Specs are here:
Diesel Innovations - Products
Should give a third more air flow and run smoother than my stock one.
Getting gauges as well in a pod arrangement on the A-pillar as well.
It's a bit pricey but I don't spend much on myself these days.
Zookie400
I WANNA GO FAST
wallingford, CT
i didnt think the gtp38r was an option for the 6.0?
hivoltage on this forum upgraded to a diesel innovations turbo, and hated it. now he is going with dual setup from them last i heard. the single was terribly slow to build boost, and caused excessive smoke at low rpms due to the lack of boost.
performance is hard to beat when it comes to a variable geometry turbo, i wish i could get one for my truck.
fordoor
SDD Member
N. Calif.
I appreciate the response so far, thankyou. Some of you are lucky and haven't had problems w/ your vgt. Some of us are on our second or third new or refurbished unit,(vgt & egr). I spank it everyday I drive it to try and keep it free and clear, so that is not the problem. It may be because I live right on the coast and subject to the harse air. I was hoping someone knew of a better replacement. If our vgt's are in fact the best, I'll just have to learn to remove and clean myself. Check out this linkhttp://www.forddoctorsdts.com/articles-06-05.php
powerstrokeguy
Weatherford, Tx
Why would you want to get rid of that beautiful whistle?!
fordoor
SDD Member
N. Calif.
You know; sometimes I feel like the only guy that doesn't like the 03' whistle, but I've learned to live w/ it. Pedestrians are much safer hearing me coming from a block away by golly! Being in construction for 33 yrs., I don't hear it like most do; and it's funny sometimes to see peoples heads snap back and figure out where the jet noise is coming from. ;tu
Brad1103
