Aftermarket radio powercycling on ignition
dpantazis
#12
under the cheddar curtain
I am getting odd behavior from new radio install. Hoping someone has dealt with it or has an idea how to fix.
2000 F-250, 7.3
Pioneer AVH-3500NEX single din. Radio was pull from buddy's truck.
I used a Matra 70-1771 harness to interconnect between OEM connector and Pioneer narness. All wires soldered and heatshrinked. dbl & tpl checked colors before soldering.
When I put the key in and got to 1st position, radio powers up and disply extends, goes through the usual radio startup.
When I turn the key to the ignition position to start the truck, the radio power down, retracts the screen and then restarts.
I do not remember the OEM double din Ford radio doing this.
I have pulled the dash apart to meter the 12V power leg on the harness yet to see what it is doing on KOEO or KOER.
any tips or hints?
Dennis
Lin50D582
